SPE Error Code 2.184
Автор Ahmed Elsayed, 02 сентября 2026, 03:06:48
Ahmed Elsayed
I have a problem with the SPE Stacker error code 2.184 and High also
I measured plug x22 terminals 30 and 32 and found 24V, the signal terminal 84 is connected to the controller.
I replaced the sensor located at the top mast, but the problem persists.
Check the height sensor B129
Check that B129 is securely fastened.
Check that the magnet is in place. If not, install a new one.
If the magnet is in place:
Check that the lateral distance and the distance between the sensor and the magnet is OK.
Perform the test of B129 TruckCom or Service Information mode 9. Low signal = actuated sensor;
High signal = unactuated sensor
2) Check wiring after the break.
Disconnect the battery
Using instruments, check that there is no break in any wire.
Measure and check the voltage with the functions activated
схема BT SPE
